Subject: 28dwarf.red From: Vision@cup.portal.com (Vision - Tester) Organization: The Portal System (TM) Date: Wed, 11 Mar 92 12:45:43 PST Message-ID: <55700@cup.portal.com> Here's a VERY simple little program for some Corewar newbies who want a step by step explanation, and a nice little warrior to practice against. He is ICWS '88 compatable(so run it on Nandor's GREAT mars88 program!) -----BEGIN------CUT---HERE---------------------------------------------------- add #28,2 ;add the number 28 to the B field of 2 ahead mov 2,@1 ;move the address(ie copy) 2 ahead at the number in the B field 1 jmp -2,#3201 ;ahead. Jmp to add instruction. # is like a DAT in the b field dat #0,#0 ;This is the guy that gets placed in memory, he is very nasty ;when executed, ie, he kills the other code. ;This program will not kill itself, for it bombs every 4, and is ;only 3 long(it doesnt matter if it bombs it's own dat #0,#0 ;it's not very efficent, but it gets the job done. ------END-------CUT---HERE---------------------------------------------------- Cut that guy out, and run it in a corewar program, and hopefully you'll be on your way to a happy and successful career in Corewar. --pete
